SIRIUS XM RADIO
mount the receiver in your top trunk...
hook it into the 12 volt receptacle for power
(CAUTION: make sure that this is only powered when the key is on...)
mount your antenna up under the lid at the top of the box...
Take the MP-3 player cord, and plug it into the speaker output port on the receiver. Plug your cord into BRP's stereo plug in the trunk! :thumbup:
That’s the way I installed mine. Just mount it this way, turn it on, and start riding. Works perfectly, and.......I have the lifetime package....no monthly or yearly reminders, mind you I’ve had mine for a goodly number of years. Plus, I can move it into my car.
Hi trikemutha,
I have a subscription to sirius (built in radio - 2017 RtL). What I do is take it by the month and then phone sirius and put a suspension on it for 6mos. while I store my bike for the winter. It reactivates just in time for the riding season. Usually???? April to end of Oct. If I ride a little sooner or a little later I'm not too worried about not having the radio for a few rides.
Well I finally pulled the plug and ordered an OYNX EZ Sat Radio Receiver with Veh Kit .... should arrive Sat. .... and will be installed Sat. :yes::yes::yes:................Mike :thumbup:.................Edit - actually might arrive Thurs.:clap:
How is the reception compared to the Shark radio's?
D
Will the reception be good mounted in the Frunk of the F3's? I have the Sharp & I only use the USB with tunes loaded on it. My Fm reception is terrible.
d
Used one for three years and finally decided to stream XM via my iPhone.
Results never looses connectivity and can change "channels" on the go.
AJ
See my post #37 above ….. Mike :ohyea:
d
The " reception " is from the " Antennae " …. not the unit itself …… I have an RT, a friend who worked for Sirius said I would get better reception if I mounted the Antennae to a small metal plate ( normally it's the metal car roof ) so I did and the reception improved..... Also reception from Sirius varies according to your Latitude in relation to It's Satellite system ….. hope this helps ….. Mike :ohyea:
