BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
So the radio arrived two days early :yes:.......I checked out everything .... the dock is 3 x's bigger than the radio itself :banghead: ....but it will all fit in my glove box......... I decided to mount the Antennae on top of the trunk in the center with a device that allows the wire to angle down at 90 degree's. I will use dbl. sided tape for this ....... I took off the inside liner and wrapped some of the antennae wire round the posts and tied them on with telephone wire ( very thin stuff ). I drilled a couple of tiny holes on the edge of the liner for this very thin wire and attached the wire down the right edge and into the area behind the passenger seat back ..... there is a lot of antennae cable, most will stay coiled in the area by the brake fluid containers ...... I laid a 30" length under the Tupperware on the right side, to the glove box ..... drilled a small hole and put the plug in..... I have a power plug on my dash but the connector supplied is HUGH ..... someone in my other Thread got Power a different way so I'll have to investigate that ......... more to follow ...... Mike :thumbup:
