Daniel Ward
Hello to all,
I know I have seen this subject on this forum before , but I don't seem to be finding anything at this moment, so forgive me if this is old information. I just installed a Show Chrome hitch and wiring system on my 2014 RT-S. Had to convert over to 4 wires with a converter harness. Everything seems to be working well. I bought the "Lumina" small trailer. Seems to be a pretty nice little trailer for the money--lights are led and very bright. Now my problem---The hitch will not stay tight. I pulled the trailer about 250 miles and the set screw on the right side backed off and allowed the hitch to start rocking on the swing arm of the Spyder. This did not really surprise me. I had a little trouble getting the threads started on installation ( it is not cross-threaded and threads are good)but I did not lock-tight the set screw. (by the way--I took everyones advice and bought new set screws that were not pointed on the tips).
I inspected everything and re-installed both set screws with "blue lock-tight". I tightened them as tight as possible (without risking stripping the threads). This time I pulled the trailer 320 miles ---about 15 miles of which were pretty rough. When I pull the hitch up and down with my hands, I can feel a little free play---not anywhere as bad as the first time, but definitely there. In one month I am heading from Dayton, Ohio to the state of Idaho and back and I sure do not want to be fighting this problem the whole way.
Some thoughts on this: Seems to me that this might happen if the top of the swing arm was "convex", because it would allow the channel to start rocking back and forth. If it ever moves a thousandth of an inch, it will eventually get loose. What about putting two small shims at each end of the channel (on top of the swing arm, maybe even two thin washers). That would give it two points to pull down on? To clarify a little---the shims would be between the top horizontal part of channel and the swing arm. Thanks in advance for any suggestions you have, or if you can even point me in the right direction to get information.
PS --I just added the heavier sway bar---thanks for all your info----Regards----Dan
