Shocks adjustable?
Hawk
Are the 2014 RT front shocks adjustable? I didn't ride it today, so I can't go out and check. Tied to my desk at work (boo).
Bummer..!!
They are not adjustable. Really don't know why the adjustable ones do help and people still come in different sizes and weights...:dontknow:
When BRP came out with this new suspension (last year); it was thought that they took away the preload adjustment, due to the new setup's sensitivity to ride height...
It was thought; that ride height changes, would affect toe-in/toe-out, too much. :shocked:
Just a thought in my part
but maybe rather than "thinking", they should have engineered this part. I need to tighten mine, but cannot.
Wonder if you removed the spring if you could add the preload adjustment collar.
Likely the pin or stop that's welded on the shock is missing??
Sent from my SCH-I545 using Tapatalk
Like Drew said the adjustment "stop" is not welded to the shock body so adding the adjustment collar is not an option for the factory shocks.
