wiredgeorge
Mostly will be riding the new to me RT (strippo model) two-up. Currently the front shocks are set on 3rd preload position and I didn't bother measure air pressure at the schader valve for the rear shock. My two-up load is about 400 lbs (I am most of it btw). What preload for front (lightest = 1 and stiffest = 5) and rear air pressure would be a good starting point? Probably, once set I will adjust from there based on handling and passenger feedback. I know, I know... I need an anti-sway bar which is in the plans when money becomes available.
