Shock mounting
Retired 2012
The shock on a 2015 F3S is a Sachs 132 mm shock and the 2016 F3-T also has a Sachs 132 mm shock but it is air preload. Will it fit on the F3S?
Good question, the part numbers are almost the same, but different.
Someone will have the answer.
If it's anything like an RT the spring on the F3T with air ride would have a weak spring and the air bag is separate from the shock.
