IdahoMtnSpyder
Well-known member
I didn't know until just a couple of weeks ago or so, when someone here said it works, that you can shift from reverse to first by just holding down the shift paddle. I thought it didn't work because I hadn't been holding the paddle down long enough. But, I can push the paddle down twice and shift from reverse to first faster than by holding the paddle.
But, here's what I found works neat. If you push down the shift paddle as you are backing up, when you apply the brake and come to stop the bike will shift into first very quickly. This maneuver saves a couple of seconds and saves pushing the paddle twice. It won't attempt to shift until you are stopped.
Not an earth shattering trick by any means, but one of those things that alleviates a smattering of frustration and enhances the enjoyment of ryding a Spyder. :yes:
