I have a 2008, does the bulletin apply to that year also? Thanks
Dealer did mine while they were working on the other issues, even though the bulletin came out after I brought the RTS in. It must have shown up on their computer, either on WebBoss, or via my VIN#.It looks like that until someone produces the actual bulletin, there won't be much anyone can do...I am getting service done in a few weeks and would like to bring this topic up, but my dealership won't even touch it unless they have data in front of them...
Call Carlo before taking it in. He will call them to make sure they get it done to your satisfaction. That it what he is there for.
I just picked up a copy of the "Drive Belt Tension Specification Change" # 2010-6 from our new local today...I just e-mailed copies to Lamonster so hopefully he can post them..I can't...larryd
I called my dealer about this today and was told that they don't do 'service bulletins' for free nor upon request.
The way they explained it to me was that there's a difference between warranty bulletins and service bulletins. Warranty bulletins are paid for by BRP, there's no charge to me and can be done whenever I want (basically a recall). But that that they only do service bulletins during normal service and that there's a charge for them.
I decided to bring my Spyder in anyway because it was just over 500 miles, so they could go ahead and do normal service (plus my mirrors were floppy again).
I'm irritated by their differentiation between service bulletins and warranty bulletins. If BRP is telling people that they should be getting this for free, they really should be communicating this to their dealers better as well.
450 N = 101.2 lbfI'm about to go buy the Gates gauge, but I'm getting some odd numbers when I convert Newtons to lbs. Everything I have found using online conversions says that 450 Newtons equals about 101 lbs. But, looking at the pictures Lamont posted, at the bottom it clearly shows that someone wrote in 450 Newtons = 331 lbs. I find that one kind of hard to believe.
Can someone say for sure what 450 Newtons equals when converted to pounds?
Thanks,
Skidz
450 N = 101.2 lbf
150 N = 33.7 lbf
so 450 Newtons +/- 150 = 101 lbf +/- 33.
Please realize that the Krickit type gauges are not a direct conversion to the sonic meter readings. Please also realize thet the correct procedure calls for jacking the Spyder up until the rear wheel is off the ground (putting minimum tension on the belt?), and calls for taking the average of three readings, with the wheel roated by 1/3 in between readings.
Scotty,
I'm a little confused; actually a lot. If you use the Krickit and you have the rear wheel off the ground and adjust to 101 lbf (450 N) and someone takes their spyder to the dealer and they use the sonic meter, the belt tensions between the two spyders will not be the same? If that's the case, how do you determine the reading you should be getting with the Krikit to equal the sonic meter.
At this point I cannot answer you. Best way is for someone to test with a Krickit after the dealer adjustment, to get a comparison number we can go by. We had a good baseline for the old comparison, but none for the new one as yet. They will never read exactly the same (after conversion) because they use vastly different methods of measurement.....and both are actually not true physical measurements, but interpretations made from the methods used.Scotty,
