This makes NO sense! I pulled the headlight relay. Headlight went out. Cleaned it and inserted and it came on again. Bad relay? So I pulled fog light relay and push it into headlight. Light comes on again. Can't be relay? So I pull the relay, light goes out. Start Spyder, thought let it shut down correctly and might reset. Guess what......all the darn codes gone, all ticking gone, throttle perfect and check engine light gone. The lump error gone. Shut it down and listen for relay to kick off. Dash etc go out and I plug relay back in. Light comes back on. Start Spyder and all errors, ticking, throttle all back! So I remove relay and unplug pedal box and no errors. Throttle Skippy, limp everything gone. Now plug in relay with no pedal box and all the errors back. What the heck is going on. With headlight relay out it shifts perfect up and down, no sound, nothing. Relay in and all errors, bad ticking, bad throttle. How can headlights be messing other systems up?
