sensor location
Depends what you are riding. Our 2016 F3L has an option under "mode" to keep the night screen on. After checking on this the only option I have is the contrast amount for night or day. With your spyder in a dark garage turned on and the night dash showing, use a narrow beam flashlight to locate the sensor and use a piece of black tape to cover it.
For an RT, it is near the speedometer and tachometer. Once you find it, a piece of black electrical tape can cover it. I assumed you were asking about night/day.
I tried the piece of tape trick. It doesn't work unless you cover so much of the display that it becomes useless.
It helps if we know which model year RT you have...
On the 2010 to 2017 models: it's at about the 10:00 position on the Analog Speedometer... but you WILL end up covering up too much of the gauge, for this to be truly useful...
