See error codes
Great..!!
hay un "app" para ver los codigos que puedes descargar gratis para las computadoras y systemas android. El app fue desenado por un miembro aqui..tiene mucha informacion para los spyders. Si te refieres a este te felizito...:thumbup:
what I want is how you can see the codes on the spyder, thanks
For the RS models:
1. Turn on the key.
2. Press the left hand button to acknowledge the startup warning thing and keep pressing it until hours are displayed on the dash
3. Press and hold both the left and right buttons
4. Toggle the high beam flashers 5 times quickly within two seconds.
For the RT models:
1. Turn Key On
2. Wait til system completes boot process
3. Simultaniously press the MODE/SET/Turn Signal Cancel Button (Push In) All at the same time
4. Any Acitive codes should then display on the screen.
Here's a pic of what it may look like on an RT. Hope this helps.
Spyder Codes..!!
the app "spyder Codes" has instructions on how to find codes, what the codes mean, what to do to fix it yourself or if it is a dealer repair. The app has many features to help you. The above post do show you how to find thhe codes if they are active. Many time you turn the engine of and on restart the codes may be gone. In that case the dealer thru the buds system can see which codes they were..:thumbup:
