Secondary Brake Strobe Light Installed
That would be a deal breaker for me, if it did not have that.
I noticed that PA18 is "California steady with pulse". I was under the impression that, for it to be legal in California, it could flash no more than four times, then had to go steady. Have you looked at that option?
My favorite brake modulator is the Kisan TailBlazer. About average price at $60, it flashes quickly at first, then slows down to a steady light. Probably not legal in California, as it does flash more than four times, but I'm not worried about that. I left California almost 40 years ago. I might vist there, but I'm NOT moving back.
I will go check that again. --- It does not seem to follow the list I posted. And no flash and then steady. The Model I received from Amazon was A-1375, and was $24.95. The same model can be purchased for $17.47 with free shipping from the manufacture LEDequipped.com.
Well LED Equiped is not responding, so a went and played with it some more and found the switching between PA numbers sequence is not up through the numbers but in the reserve order. So I am reordering the info from the early post here. And PA21 does not appear to be in the A-1375. Regarding the California ones, their code says no more that four flashes in the first four seconds. (c) Any stoplamp or supplemental stoplamp required or permitted by Section 24603 may be equipped so as to flash not more than four times within the first four seconds after actuation by application of the brakes.
Switching instructions:
Less than 1 second for next pattern
About 3-5 seconds for steady burn
More than 5 seconds to turn off
PA22. Off
PA21. Cycle Flash – Split & All Does not appear to be present
PA20. Steady All
PA19. California Steady
PA18. California Steady with Pulse
PA17. Express Flash
PA16. Accelerator - All
PA15. Accelerator - Split
PA14. Quad/Single w/ Quad Burst
PA13. Quad/Single w/ Quad Burst - Split
PA12. Super Flash - Alternating*
PA11. Super Flash - All
PA10. Super Flash - Split
PA9. Single – Alternating*
PA8. Single - All
PA7. Single - Split
PA6. Quad – Alternating*
PA5. Quad - All
PA4. Quad - Split
PA3. Quad Burst – Alternating*
PA2. Quad Burst - All
PA1. Quad Burst - Split
