Seat question/options?
CANUCK SPYDER
Hey Folks, Just thought I would inquire about this. I have a 2008 GS and have upgraded with the BRP Comfy seat which is waaaay better than the OEM 2X4. I have added few other expensive pieces too make it more ridable for long rides and all are succesful.(HELI-RISERS,Floor boards,Hi-way pegs) But when I sit on my trike it would just be better if I could could sit back farther like right where the hump is that separates the driver/passenger which I never have behind me anyway. Im thinking CORBIN may supply a seat? Or maybe a seat that is more flat across it without the hump between driver/pass Any suggestions? Im not overly tall at 6' but anything too add too the riding would be cOOl Thanks Doug
Seats
Hchays has a nice Russell day long seat for sale on the for sale board. I don't know where that falls in the leg room category, but he is 6'6". The Corbin is an inch closer to the bars than the stock seat. At least the one I have is. The st seat is an inch farther away from the bars than the stock seat. Does that help any ?
Hi Dave here
Well let's see if I can help since I have the same Spyder as you I have the HEILI BAR risers the Rivco floor boards and the
corbin seat.... however there is not much left of the corbin seat mostly just the pan... the stock seat is one piece the Corbin
is 2 sections front rider and rear passenger. the front section puts you closer to the area that would be a gas tank on a motorcycle so it puts you much closer than the stock seat so unless you are a shorter person say 5'6" to maybe 5'10" you will
have to modify the Corbin a bunch... I have a brand new Corbin in the shop right now I am going to attack on Tuesday and do
the same I did for mine, cut the seat back as far as possible remove most of the foam you sit on replace it with GEL and memory foam and make a new cover for it to his specs.
On a Stock seat or on a comfort seat it is not as involved all you have to do is remove the cover and mark the seat where you
to be sitting and cut away all the area that is in the way, this requires cutting off some and then sitting on it for fit if not right
keep doing it until it feels good to you, then install GEL if you like or just put a layer of memory foam and put on the new upholstery/cover.... you need a new cover because your old one will not fit.
Go to my website and look at the pictures in the photo section also go to my upholstery website and check photos there
www.davesvcu.com and motorcycledave.com
Good luck on your seat adventure
Ride Safe
Dave
:f_spider:
Thanks Dave will have a look right now, yes seen some examples there of what would be what im thinking. Guess I shouldnt have sold my OEM for the $50 could have had it fixxed up over the winter. D
I have an extra OEM seat
I have the original sear from my 09 boxed up in my garage but getting it to you might be a hassle. It could be the pan for your new Day Long. We could explore it.
Thanks Dude but your prob right getting it here, Quite sure they show up on trade and sell once in ahwhile. Kinda kicking myself sold my OEM for $50 I think D
