I got the brake "riser block" and installed it. I made a slight modification to the brake pedal when I first got the boards to make it a bit higher. One of my concerns was the brake pedal/pad coming loose which it did on my way to Boston a while ago. When I tried to tighten it I stripped the threads and made a modification that I decided I liked better, so I stuck with it when I added the aluminum riser. All I did was drill through the top of the pedal and inserted longer stainless bolts and lock-nuts. I feel it makes it more secure since it is raised up above the pedal and no longer "meshes" with the top of the pedal as the original brake did.
