Sny
My wife and I both have new 09 SE5's.
When I come to a stop on a flat surface, I can take my foot off the brake and it doesn't go anywhere.
On my wife's SE5, on the same surface, if she takes her foot off she moves forward under power (it's not just rolling)
I didn't even realize the difference and she didn't think anything of it because it behaves like an automatic car.
My somewhat limited understanding of the electronic clutch in the SE5 says that shouldn't happen.
The only reason I even noticed the difference is mine did that once, took my foot off expecting to roll backwards a bit (was on an incline) and it went forward without any throttle.
I don't really care which way it's supposed to work, I can get used to either, but the inconsistency is killing me :sour:
Is it different on a flat surface vs an incline? decline? Should it behave like it's in neutral until you roll on the throttle?
Does it change as they break in? The transmission certainly needs a healthy break-in before it behaves normal, maybe that's all it is.
