SE5 Clutch Wear Question
manttila
I know when I have had a few manual vehicles and when the clutch would wear it would slip. Especially at higher gears going up hills.
What are the symptoms when the clutch on the SE5 is starting to wear out?
Thanks,
Gotta say..!!
pertty much the same. Just make sure you run it at high rpms. Your clutch will not be fully engaged under 3,500 rpm's. Though mine is manual I do run from 5,000 to 6,000 rpm's...clutch will last a long time if you don't lug the engine or slip the clutch. First on I saw go was at over 60,000 miles...:thumbup:
