screws air filter rts 2016
I use a 3/8 drive T30 torx bit with a 6" extension for two of the bolts and no extension for the third. It's obvious which bolt needs only ratchet and bit. M6 is the size of the thread diameter and 16 is length of the bolt in mm. The bolts on my '14 remain in the cap when you remove it. There is an orientation arrow on the cap so you can't install it improperly.
Thanks
thanks
