Schrader valve
Rookiespyder
Hello out there, what is the maximum amount of air should be in the schrader valve when not sitting on the spyder. Thanks
Read your operator's guide; it's in it.
:ohyea: …………. and I'm thinking you mean what psi is in the rear air system ???? ………. there is a warning sticker under the seat near the valve, that will tell you what the Max is …… Mike :ohyea:
Since the sticker next to the valve recommends that you not exceed 10 psi OVER the recommended chart and the pressure for 250 lb driver and 250 lb passenger is 85 PSI, I would say 95-100 psi....I usually try for 50 psi 1 up....
Since the RT Limited's all have an automatic system to keep the pressure adjusted, I don't believe that chart is in the owners manuals for those models.
AND....that valve is there mostly just for checking to see that the automatic system is working.
If you manually add or remove pressure, the system will go back to what it wants to be.
Indeed it is - at least for the 2014
AJ
