safety
Machinegunner
Now I can change the subject. Last Friday I needed to make a part for one of my handguns. I went out to the shop and set up my lathe. I started to do the work when suddenly I was pulled down to the ways. Luckily I was able to push myself back far enough to tear my shirt. That gave me enough of a stretch to reach the switch. Had I not been able to reach it, my wife probably would have had to tell you what happened. I didn't follow safety procedures and had a loose shirt on. It got caught on the lead screw and got wound up. Luckily it was turning slower than the chuck. Be careful around machines and pay attention it can happen very fast. My torn shirt now hangs in the shop as a reminder.
:yikes:
Thank Goodness, that you're the one telling the story... :thumbup:
:lecturef_smilie: But don't try that crap again: we'd miss you too dang much! :shocked:
I almost lost a hand to a table saw that had its safety arbor removed because it was 'getting in the way'. But then I've always been a klutz. Interesting to hear even skilled tradesmen sometimes make those kinds of mistakes.
Yikes...!!!
Been there and fortunately was a cheap shirt and ripped away like a strippers costume :roflblack: but your right it does happen in a split second :yikes: glad you were able to get away from it...:pray:
From the CPA office. Ties and paper shredders are not a good combination either. One of the staff went all the way to the knot before he was able to shut it off. :yikes:
I have a cracked helmet above the door to my garage of an incident that happened 3 1/2 years ago (the reason I got a spyder). I could have sworn that my head never hit the ground. But my 30 minutes of memory loss, and the cracked helmet begs to differ:shocked:.
I remember rescuing a summer intern from a paper shredder once.
Ron, I'm glad you got the machine shut off in time.
Years ago I worked in the state offices in Baltimore building their new Medicaid computer system. They had a brand new data center and the supervisor believed in presentation so he put a big sign on the doorway "Ties Required in the Data Center". Several of us tried telling him it was a bad idea but we were just contractors so didn't have any sway in their organization.
There used to be a machine in every data center that read and punched cards. It was called a 2540R and it could ingest hundreds of cards per minute. It had a big vertical tray at one end which is where the operator stacked the cards to be processed.
A few days before we went live I was making some last minute changes to some programs and brought a cart full of cards in to be processed. The only person there was the supervisor so he began loading them. Apparently, as he was leaning over the stacker reaching for more cards, his tie landed between the sections of cards and it was but half a second the machine grabbed his tie and choked him right down onto the stack. Fortunately I was standing nearby and hit the safety switch but not until his face was thoroughly punched and his tie shredded. He wound up with a very visible ring around his neck and a black eye.
The next day when I came into the data center there were the remnants of his tie along with a new sign taped to the computer console: "Ties and Long Sleeve Shirts Prohibited in the Data Center".
Several years ago my ponytail touched the chuck........That was the day I cut it off. I thought I was safe then. I wasn't. Just lucky. Too soon old, too late smart.
I'm glad that I work in an office...
About the worst that can happen to me in here, is that the Missus could clock me with a stapler.:yikes:
Ron,
Some day about a million years from now: an archeologist will find what's left of my carcass...
He will no doubt be amazed at all of the damage that I've sustained! :roflblack:
Two wrists
a leg
a foot... Twice!
an elbow
a detached retina
and a busted rib
Ron,
Two wrists
a leg
a foot... Twice!
an elbow
a detached retina
and a busted rib
one badazz insurance office! You might screen your clients a little closer! ��
glad you are ok, Ron!
"No job is so important and no service is so urgent that we cannot take time to perform our work safely." -- AT&T Safety Creed
At one time the Bell System was the largest company on earth, and was self-insured. Safety was pounded into us constantly. But the most danger I ever faced was knocking my shins on an open desk drawer, or the open top drawer of a filing cabinet causing it to fall over. But that wouldn't have happened because all of them were bolted to the walls.
