Spyderdale
Just wondering where you Rally riders are setting your front shock preload. 1,2,3, or 4 ? For reference I weigh 200 lbs. Just trying to a good feel for my new Ryker. Thanks
I'm pretty much set up about the same as Cueman, 225 to 230lbs 3rd ring on my 2020 Rally. It performs best at those settings. I've experimented with both softer and stiffer setting and the third ring performs best for my weight and the type of surface (roads) that I ride on. I've also set the rear stiffer because the saddlebags, top case and contents has added additional weight.
How was the ride different at 4?
So I have had a Rally for about a year now.. I bought it pre-owned... i have adjusted the rear shock several times trying to get it tuned to me but I guess i never realized I can tune the fronts.... Upon looking at it, it it set to 4.... On back road it handles great but on the highway it always feels a bit twitchy and always makes me uncomfortable to cruise at highway speeds.. thinking that if i adjust it to 3 it might help with that. Going to have to try this week.
I also have the full baja ron sway bar.
Just curious, did you also replace the end links? If so, the sway bar and end links should have done wonders with that twitchy feeling.
The original owner put the baja ron sway bar and end links on. It handles amazing but when cruising at like 70+ on the highway it just feels twitchy. Maybe jittery. Slightly unstable. Its hard to describe. What i dont know is if this is because its the way mine is set up or if its the nature of the ryker.
- I don’t think its the tires or it would show up at other speeds.
- I also don’t think its worn steering components as I only have 2600 miles on it (1200 by me)
- It could be rider inexperience such as holding on too tight, everything I have read said to give it a few hundred miles and it would start feeling more natural but it just hasn’t yet.
I am going to try to adjust the front shocks this week as they are VERY FIRM.. when i try to push down on the font end it barely moves so I am really starting to think with the firm settings and sway bar with end links its just too firm and I am feeling every little imperfection in the road creating a “skipping sensation”
