wmh9680
Good morning. I went to Cabela's and purchased solid stainless crappie something or other thingys and ran it to the drivers left wheel well and it works good. It's strong enuf the cable will never break. I would like to find some stronger barrel swivels though.
Is there anyway to disconnect the cable form the ignition and run it out the dash by the windshield (same with the cable for the seat)? Or as you can see I drilled a small hole in the lever and would like to run a new cable up behind the windshield. I have ran it up there but it has too many turns and puts to much stress on the cable. Is it hard to remove the black plastic with the 3 screws in pic top frunk? Also the center frame with the UPC on it I think is plastic or light weight metal and I could drill a hole in it to run the cable straight up. I could mount it on my acc bar behind the windshield. This way I could open the frunk while still sitting on the seat. I don't want to beat this to death but just trying to make it not noticeable but easy and strong enuf to never fail. Thanks, Mike
