Rts stalled out twice.
Brentc
I have a 2014 se6 rts with 15500 miles on it. Always use high test and have done all service at dealer. My bike stalled the other day twice from a dead stop when I give it any decent amount of throttle. It is worst when engine is cold. I almost have to feather it as though I had a clutch in order for it not to stall. I’m wondering if anyone has any suggestions? I’m thinking the timing may be off, or possibly fouled plug?
STALLING
BRP recognized this issue ...... and there is a Dealer fix for it .... they change some settings with BUDS ....I had mine done under warranty, awhile ago ..... Mike :thumbup:
my 2012 Spyder stalls every time I stop. I have to say that I haven't used it much, and the fuel may be very old......initially it did not stall, now it does. I doubt vacuum line......could it be anything else....?fuel filter. thanks
Sounds like a trip to deealer
Thanks Mike, I'll head to dewater and see if they can tweak it.
Update
My dealer wasn’t aware of any update to address the stalling, but he said there was an ecu update. So he hooked it up and applied the update. Seems to run a little better, but I’ll keep an eye on it. They said they’d open a case with brp if it happens again.
UPDATE
:roflblack::roflblack::roflblack: ..... What does He think CONTROLS the engine :banghead: ... tiny Spyders :yikes:..... Mike :thumbup:
RTS stalling
???'s, do you still have the OEM fuel filter, have your plugs ever been changed, do you have the original wires, have you ever replaced the vacuum hoses, has the air filter been changed. Those are what comes to mind for anything else. JMO, but I don't own an RT.
Al in Kazoo
Mine was doing the exact same thing and the problem turned out to be the wires. I replaced every vacuum hose on the bike. Did the purge valve bypass. Checked everything. Replaced wires with the ones from here and the bike came alive. Had not had a problem since.
Jim.
