I found a problem with Lamonsters fix.
After a time, the mirrors start to shake again.
The metal screws, threaded into plastic holes started to back out, loosen the mirrors thus allowing them to shake again, albeit far less than the original problem.
I didn't think anything like Locktite would work, so I wrapped the screws with teflon tape, typically used to seal plumbing joints.
I'll see if this holds up.
I’ll try my dealer, and see if they will fix it. They never did the F3T.
The kits can now be ordered from BRP dealers and are free of charge. Service dept. will install, takes 10-15mins. Bolts replace lower clips.Any info on this kit ?
Just had mirrors on my 2020 RTL upgraded - now rock solid! :2thumbs:
Thanks, I trailered my 2020 Spyder to MN this summer and noticed that my mirror was looser after getting there. I will try the Lamonster solution.
I have a 2021 RT LTD on order and have an email out if this affects the 2021 model year also.
There is a service bulletin out on these mirrors.
Do you have the name or number of the service bulletin? My dealer didn't know anything about it and opened a case for me. Waiting on a response. Although, I have Squared Away's fix and that took care of the problem.
+1I contacted my dealer, he is ordering the BRP fix.
If it's still under warranty why wouldn't you go for the mirror fix from BRP, it free???
