RTL 2015 cruise control some times work some times do not work
You are not accidently touching the brake pedal by resting your foot too close are you? Not enough to apply the brakes, but the nanny might think that you are and not allow the cruise control to engage.
Tap the brake pedal a couple times, and / or pull up on the pedal with your toe. Sometimes, and it is a maintenance item is to clean the switches per the manual.
Ours does it too at times, now I typically pull up with my toe after a braking event.
I have plans to modify the the design and stop this issue for good.
