ulflyer
Wanted more room for the Springfield trip so I bought an aftermarket trailer hitch ($185) and rack($75). Decided not to use the rack itself as its made of steel and fairly heavy but used the mounting bars and some scrapwood to bolt the plastic trunk ($10) purchased at Walmart. I put some rubber molding around the lid to make it reasonably watertight although any clothes I put in will be in a plastic bag just to make sure. The two latches have provision for a lock or pin to prevent coming open.
After getting it all done, I couldn't clearly see the lic plate so thought it prudent to put it on the trunk. The trunk can easily be removed by pulling a couple of clevis pins so I'm considering drilling the ends of the pins so that small locks can be put on. I plan on leaving it on and trying out various loads and to make sure it holds up well.
