spyder stryder
RT vibration
My 2012 also had this vibration, the dealer adjusted the belt several times
without helping much.Then we started checking the belt and the sprockets,
what we found was the engine out of alinement. Like the front was over to
the left to much causing the belt to ride hard up against the outer back edge
of the drive pully.Looking at the outer edge of the belt you could see where it
was wearing on it.He loosend the engine mounting bolts an used a 3/4 round
bar to push through the line up holes ( had to do a little wiggleing on the engine)
so the bar would go through then retighten the bolts. Reset the belt tension,so
far so good in the last 400 miles. Might need to have your spyders checked for this.
spyder stryder
I feel your frustration my friend, catch 22 to say the least. I could almost tolerate a 400 rpm range of the drive belt flapping around. But for me its 900 to 1,000 rpm range of continuous drive belt flapping under acelleration and at a cruise. I have to put up with this in 3rd, 4th, & 5th gears at 5300 through 6200 rpm.
Like you I like the Spyder RT, but if we don't get any resolution on the drive belt problem. I'm afraid I'll be sorry indeed the day I bought it.
Come on BRP step up to the plate and get this fixed.
A very concerned Spyder RT owner.
spyder stryder
