Bob Denman
Maybe just not cognac
Bob
:gaah: Who do I have to sue over this? :roflblack:
Bob
They look great. So are they from BRP or aftermarket?
Guessing this was more plug and play since the bodywork on the 14 / 15 already has a grille in the scoop location. Possibly no cutting was even needed???
The upper body panel design has remained unchanged. Same design 2010 thru 2015.
The scoops look nice and no doubt cool the cowled areas.
The question I have, is with the scoops blocking the airflow around the bodywork, it seems the riders would have less airflow. This assumes you had the adjustable BRP deflectors. If you ran the stock wind deflectors it is probably the same.
With the adjustable deflectors, it can force air into the upper oem grille, and also aim the airflow towards the riders.
I had the adjustable air deflectors and I am not impressed with there operation. Yes they allow air to flow back to the rider lower body but because of the venturi effect it draws hot air up thru the vent located there. To prove this just put you hand in the area of the vent and you will feel the hot air coming out thru the vent directed back to the rider. Here in South Georgia in 95 plus temps and a heat index of over 110 all you need is more heat from the engine compartment.
Curious what you found is the best setup.
My thoughts are I want to cram as much air under the tupperware as possible to move the hot air out. I have the vented windshield to put air on the upper body. Don't need it for the lower body because of the new design of radiators on the 2014-2015 RT.
PK
What kind of advantages are you seeing with this?
may i ask how much were they and how did you cut the tupperware, did the temp-let come with them and how do they mount. i like the way they look
LOOKS GREAT !!
Where does the air coming in through the vents, vent to ?? Out the lower vents on the sides ??
Out thru the sides and bottom.
Just wondering cause on my new 15 RTS, I am having excessive heat issues (coming out the lower vents on each side and venting big time between my seat & glove box area).
I know there will be some heat (heck your sitting almost on top of the motor), but I'm getting WAY more heat than my 2011 RTS did.
Think I'm gonna post this as a question in the forums. I'm rambling here !! Sorry !!
Tommy J.
You can order any color as long as it is BLACK. If you want matching colors you will have to get them painted yourself.
They are the BRP Scoops. Part number 219800388. As mentioned in other threads they are $67.00 plus tax. The vents are a great accessory at an unbelievable price from BRP.
Cooler glove box and seat area
Price above. You don't need the template. Send me a PM with your E-mail address and I'll send you a PDF file on how I did the install.
As explained above. Plus one of the very first mods I did was the CAT Bypass.
If anyone wants the instructions on how I installed them without the template send me a PM with your E-Mail address.
Does the 2012 RT need them
My opinion is the Air Vent Kit is the best Mod that can done on any RT (2010-2015). Yes you should do it and it is only$67+tax but you should get BRP to install them for free.
BRP agreed to provide them and have them installed for free for me after a call to my dealer about excessive heat.
ZERO charge to me. They were installed yesterday and work beautifully... I had them installed on my '11 RTS.
No one with a pre-2014 RT should be paying for these or their installation.
Push the heat issue with your dealer to get these for free from BRP. The dealer is getting them for free and is being paid to install them; so you should not have to pay.
"if you pull up the 13 recall it comes with the temp-let"
Not sure why this is true. All the 10 thru 12 owners told us 13 owners repeatedly for years they did not have heat issues. Told the NHTSA the same thing and were dropped from the investigation for that reason.
As has been reported here in another thread there is a TST # 112333 that addresses the installation of the vent kit on the 2010-2012 model RT's. It is available to those owners thru BRP as stated.
Its interesting to see 2014 and newer bike owners wanting the cool ride the 2013 bikes provide.....
