Ok, it was only 89 today so I took the bike out at about 5:00 with the sun still beating down and came back at twilight and and have proven to myself two things: The direct sunlight makes a huge difference and is responsible for most of the “too hot” experiences in the dash and glovebox area.
However, even out of the sunlight on the ride home, there is very hot air coming up through the gaps between the panel and the handlebar/switches area. And the bottom speaker grills or vents have very hot air pouring up through them, even at 75mph. The glovebox is also still quite warm even after dark, especially at the bottom. I will inspect its insulation as much as I can when I get the plastic off next.
So if I only rode < 90 F, I think no mods would be needed. But since that excludes 3-4 months here, I’m going to try the vents and extra insulation.
(I was going to take actual surface temp readings but my infrared thermometer has broken. Replacement on the way.)
Your informal test validates how the acoustic panels not only serves to offer up a quieter experience from the engine, but also serves as a form to double insulate the exterior bodypanels from engine heat, and airflow leakage from the bodypanel seams.
Myself, I never understood BRPs logic of complete removal of the acoustic panels. The heat barrier of those acoustic panels and secondary foam insulation bonded to the acoustic panel even further insulates heat from the exterior bodypanels and rider / passenger.
Yes, installing the scoops will improve the airflow behind the bodypanels, provided there is forward motion, at adequate speed to sustain that airflow. When that airflow into the scoop is diminished, the heat and airflow behind the bodypanels becomes stagnant, ultimately heating those bodypanels the rider touches.
While obvious heat rises. This heat rising, while semi trapped behind the bodypanels, will search for any exit as it heats all surfaces. The heated air can only be forced downward, if the scoops are functioning via airflow from forward motion.
If you want a cooler experience, properly insulating the backside of all the applicable bodypanels is how to achieve less heat passed to the rider. Unfortunately, the heat barrier products, best suited for the task are expensive.
In a previous reply, you mentioned reading about someone having replaced the oem inexpensive foam that had deteriorated. I suspect that was me, as much of the bodypanels and acoustic panels on our Spyder are lined with an exotic and expensive self adhesive insulation we use to insulate aircraft fuselages from the extreme heat and cold at altitude.
So between the double barrier of the oem acoustic panel, and bodypanels, along with exotic insulation, radiant heat from the Spyder is a non issue, the true challenge now is the SoFlo sun trying to cook a person like a Thanksgiving turkey.
FWIW, when we ride, regardless of ambient temps, the gear worn is a full coverage Shoei helmet, long pants, BRP mesh jacket over a shirt, full fingered gloves, socks, and shoes. That alone can get hot, I can only imagine how much worse it would be if the bodypanels added more heat.
Will offer up something I sometimes do. If we stop for a short time, and the Spyder is shut down, there are times when the rising heat will get the Corbin seat a bit warm. Once remounted and moving, our fuel filler access door in the seat, which faces forward, I will open that, as if a ram air scoop, and within a minute, the actual seat temp is restored to a comfy level. This does not happen often, but is a huge benefit when needed.
