RT service
Cindi
I had my 2014 RTs serviced the second time at 14,300 miles. It now has 20,200. Should it be serviced again? If not, when? I've got conflicting information on this. My oil level is good, but the oil is getting dark.
There is a current thread running with the "technical" information.
Bottom line. Initial break-in oil change 3000 miles. Subsequent oil changes at 9,300 miles later (12,300), and then 9,300 mile intervals OR once a year. You have 6,000 miles on your current--if you are not at a year since last, you still have 3,000 driving more miles. :yes:
If you now have 20,000+ on your Spyder you should replace the air and fuel filters. You will find the schedule on pg. 122 of your Operator's Guide. The instructions for changing the air filter are on pg. 127 if you want to try it yourself. The fuel filter is not hard to do but takes a bit more time than the air filter and requires a pair of special special pliers if you are going to use the Oetiker clamps that come with the fuel filter assembly. The instructions are in the RT service manual. Doc Humphreys has videos on replacing both filters at this site: http://dochumphreys.wixsite.com/roadster/install.
