Does anyone actually have the specs on the OEM Kenda KR31 165/55R15 tires? I've used the advanced search function for here and the whole Internet, not a trace to be found. The Kenda website doesn't even mention the tire.
The reason I ask is I just received 2 new Vredestein 175/55R15 tires from Tire Rack, and they were very light. Almost motorcycle tire light. So I pulled out the old measuring stuff and jotted down a few numbers. These were not mounted at the time, which may make my dimensional numbers off somewhat. I'd like to compare the specs of the Vredestein to the Kenda. There is a pretty good lack of specs for the Vredestein's as well, but you can find more than the Kenda.
Vredestein 175/55R15 Specs as measured by me not installed.
Diameter (Inch) 22.4
Circumference (Inch) (Tape Measure) 70.75
Section width (Inch) 7
Tread width (contact patch) (Inch) 5.75
Weight (Lbs ± 1/4 lb) 13.25
Load Rating 77T (908lbs)
Tread 2 Ply Steel 1 Ply Polyester
Sidewall 1 Ply Polyester
There was also another sticker on the tire which had 3 symbols. Gas Pump was rated C, Tire running through rain was rated C, and Noise was 68dB. Not sure what this means as the traction is rated A right on the sidewall. Mine were made in the Netherlands 28th week of 2018. Shout out to all the folks giving us the years of actual hands on experience to make these selections easier.
