SilverSurfer
RT-S PE#0391
Okay ...
Last Thursday I had my RT in the shop to do the 2010-6 bulletin on rear suspension re-calibration. What led me to have the inspection/re-calibration done was potential shock topping out if I pressed hard on the trunk. They performed the tech bulletin; I picked up the Spyder the same day and it seemed better. but when I rode home, I sensed the rear of the Spyder was 'low', plus my riding position now had me looking under the top edge of the windscreen (at its lowest position), where before I am always looking well over the top.
Yesterday I started the Spyder and let it run for a sec to get everything set. I turned off the Spyder and checked pressure on the Schrader valve. 7.6 pounds!!! This told me that perhaps the mechanic forgot to re-charge the schrader after the performing the steps in the bulletin. So, I re-charged the schrader to 30 pounds. I watched the bike rise up to its normal height. I then went out for a five hour ride. I got back to the house and measured the pressure on the shrader valve: 26 pounds. hmm. I don't want to say something's leaking because I know the ride sensors and other stuff may have caused the Spyder to bleed off some air pressure from the suspension ...
HOWEVER:
I'm a little mystified as to what's going on. The mystery now, is different than the mystery before. The suspension calibration seems to be working fine (no shock top-out). But since the calibration re-set (lengthened) the suspension's range of play, what is now revealed is that the air compressor for the ride control *may* ... and I repeat ... *may* have stopped working and I need to monitor the schrader valve pressure manually. This may have been what threw my calibration off. If the the ASC compressor stopped working, maybe the computer over-extended the suspension to pick up the slack? I dunno. When I get back from Maggie Valley ... looks like we're back into the shop.
HOWEVER:
