RT rear turn signal bulbs
pickelhead
I need to replace one of the rear turn signal bulbs. I bought an 1156, but the 2 pins that lock it in place are different. The 1156 pins are 180 degrees apart, the stock bulbs are less than 180 degrees. :dontknow::helpsmilie:
The 1156 has a base designated as BA15S which includes pins that are 180 degrees apart. You need a bulb with a base designation of BAU15S which includes pins that are offset not opposite each other. Both bulbs have an S8 shape so they look similar but the pins are not.
:shocked::hun: :joke:
I've got to crawl back into the coffee cup for a second dip before I can even begin to figure any of that explanation out...
But thanks for posting it!! :2thumbs:
Oh! I sure don't mean to make anybody think that what you were saying wasn't right; I'm just not very good at technical stuff and have to get my paws on things before the parts of the puzzle start making sense... :opps:
The cost and shipment time from BRP was too long, so I just got a regular 1156 build and used a Dremel to grind down one side, works great. :ohyea:
RT turn signal bulbs
Thanks for the information on the bulbs. This is a new one on me and I'm ready for it when mine burn out on my 2010 RT.
47234]The 1156 has a base designated as BA15S which includes pins that are 180 degrees apart. You need a bulb with a base designation of BAU15S which includes pins that are offset not opposite each other. Both bulbs have an S8 shape so they look similar but the pins are not.[/QUOTE]
I got correct spare back-up and turn signal bulbs on e-bay. The turn-signal bulb (with offset pins) for $6.50 from AutoLampsPlus. The back-up bulb (180-degree pins) from bigrodj for $5.44.
Note that the 1156 is rated at 26.9W, 2.1 amps. The bulbs I purchased are 21 watts, 1.7 amps. The owner's manual specifies 20W for both bulbs. Normally I'd say brighter is better. Just be aware that you're drawing over 25% more amps than specified. Probably no big deal at these small amperages.
17638na napa bulb
napa has this bulb 17638na under $3.00:ohyea:
Good find. The on-line NAPA specs don't show the watts or amps or if the bulb is tinted but the base shows the 150-degree offset pins and the bulb shape as S8. Hopefully your packaging shows the watts. Next time I need one, I'll give NAPA a try. Thanks.
