Not to sound stupid, but does anyone know what the optimal air pressure should be for the rear shock on the RTL? The only thing the RT Owner's Manual refers to is related to the manually adjustable suspension. It recommends, according to weight, anywhere from 70 to 90 psi according to the load. Assuming that the onboard compressor is working, should the psi at the schrader be 70 minimum with one up, and then pump up to allow for load i.e. stuff in the storage compartments & a passenger? If the passenger gets off during a ride does the psi go down? Honestly, I have never heard the compressor on my RTL start up, but then again, I do not know what to listen for. When the wife & I ride two up with the frunk, rear & side storage areas (with luggage) full, I set the suspension to the firmest level, but it seems to me that there is a lot of body roll in curves, much more so then when I ride alone. I understand that adding another person changes the dynamics, but it really seems extreme to me. I have never checked the psi, but now that I think about it, I probably should, just to establish a baseline.
Any thoughts would be really appreciated.
