BlueKnight
Well just finished up installing the High Mount Brake Light with the dual converter circuit so its lights up as a driving and brake light. Also installed the rear Brightsides with the Rips kit so its functions as a marker and turn signal light. And also installed a Back-Off Wig-Wag brake flasher, I have it wired to alternate the brake lights, then flash both lights together, then as long as the brake lights are on, it flashes both lights together every few seconds. I love these OEM light harnesses that Tricleds sells, makes it alot easier and you don't have to hack up your bikes harness.
One problem I have run into is that I've noticed that the turn signals do not activate on the first push of the button all the time...not sure what is causing this.
Onto the front end now.....Amber Brightsides, Mud Flap lights, Fender tip Lights, and the Tricfenderz Lights.
