RT Mirror Electrical Connector for Signal Lights
Thanks Roger,
There are a lot of different models in the Delphi line up, do you have any idea which the correct one? I.e. 150..280...?
I believe these are what you are looking for. I posted this on an earlier thread today but I guess that thread has been deleted since I cant find that thread anymore. I have used these to install some of the mods on my Spyder.
1 pole connector - http://www.touratech-usa.com/Store/PN-015-0079/AMP-superseal-1-pole-connector-set
2 pole connector - http://www.touratech-usa.com/Store/PN-015-0080/AMP-superseal-2-pole-connector-set
3 pole connector - http://www.touratech-usa.com/Store/PN-015-0081/AMP-superseal-3-pole-connector-set
4 pole connector - http://www.touratech-usa.com/Store/PN-015-0082/AMP-superseal-4-pole-connector-set
Little checking..!!
have seen these on ebay running $2.95 in the waterproof connectors. You have good links above so you should be able to get what you need. There are others and as long as you have both male and female work just as well..:thumbup:
While at first glance they appear to be Delphi connectors upon close examination they are not. Not sure what the manufacturer really is but the ones YIRYDE gave the links to are the correct ones. I want to find the manufacture to see if I can buy a kit, any one know who actually makes these?
Please post or if you find a kit a reasonable price.
These connectors work great for adding LED's to the panels when you have to remove them maintenance.
TE was formerly known as Tyco Electronics. The AMP Superseal connectors are their product. Be aware that there are several versions...these appear to be the Superseal 1.6 or Superseal 1.5 versions. A number of electronic suppliers handle them, but I have not seen any available kits. Let us know if you find something.
I ordered some completed kits with wire on eBay. I will let you know in three weeks when arrive.
Is that a good, "Wow"? :shocked:
Can anyone identify the type of connector used for the electrical on the mirrors?
Thanks
AMP/TE Connectivity Superseal Series 1.5 two pole. You can buy all the pieces to make up what you need from Newark Electronics. http://www.newark.com/webapp/wcs/st...st=amp superseal&pageSize=25&showResults=true
I just used several of the 3 & 5 pole connectors for my light modifications. If you want to go with Newark I can tell you exactly what parts you need. I got my order from them in about 5 days. They had the best price.
