RT Frunk Weatherstrip
GLHRN
I bought my RT A/C 8-2011. I love the Spyder, but one thing REALLY frustrated me and that was the frunk weatherstrip. It would continually pop off and I had several "choice" words when it kept popping off. The dealer replaced the weatherstrip and adjusted the frunk twice, but still kept popping off. I just recently bought from SpyderPops his replacement frunk weatherstrip and I am so THRILLED with it. I have opened and closed my frunk several times and it does not pop off and the frunk has NEVER opened and closed so easily. Thanks to SpyderPops for a GREAT product! :clap:
I hadn't realized that Spyderpops made a replacement. I hardly use the front trunk mostly because it is such a pain when the strip falls off.
i bought the trunk liner for my RSS and it is now 'stretched' so when it pops off i can never get it fully around again.
am getting the replacement from spyderpops and if it is not long enough am gonna splice the 2 of them....
but mine only popped off because my dumb:cus: keeps knocking it....:banghead:
I just installed my GS/RS trunk liner. The elastic part of the liner has piping on the edges. If this piping is not lower than the gasket when the gasketing is in place, the gasket can pop off. This is just something to look for.
I purchased the New RT Funk weatherstrip from Spyderpops - It is so much better than the OEM - Loook better and fits so much better
Mine has not come loose like my old one did
If BRP is still using the old supplier they should contact Spyderpops and bulk buy his supplies and fit them as standard - That would be one of
their problems solved
Well done Spyderpops - Hope your working on more upgrades for the RT
Eddie Sheppard
Reading UK
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 - Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
Full Size Brake Pedal by Steve = TricLed.com
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
LED Light in Rear Trunk
Elka Shocks Stage 1 +R – Front and Rear
Shock Covers
Track Rod Covers
Spyderpops – BumpSkid .Missing Belt Grard & New Funk weatherstrip
BaJaRon – Custom Ignition Wire Set + NGK 2 Iridium DCPR8EIX. Spark Plugs
K&N Air Filter
Sport Tall Wide Clear Windshield – Cut down to 24” High
Chrome 2011 Front Lower Wind deflecors
Utopia Backrest
S/S Seat Prop
S/S Handlebar Weights
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Mirrors Zipped tied for added potection
Rubber Tank protector on glove box
Grip Puppies
Switch in Swith Cluster for Manual Fan operation
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front/Rear J&M Speakers
Bluetooth Via Sony transmitter TMR- BT10 - On board Radio to Sena SMH10 Headsets
