RT-622 Water Intrusion Problem
pwilbarger
I have 2010 RT-622 the I bought new with my RTS. Last year after riding in the rain there was water under the carpet and in the two shallow recesses at the front. I removed and dried the carpet and got the water soaked up. I figured the lid seals were bad and replaced them both with the better ones from JT Industries. I hadn't used it in the rain until this years SpyderQuest. It rained all Saturday night and into the morning. The trailer was parked most of that time at the motel. I didn't pull in the rain until Sunday morning when I left for home and then only rode in the rain for about 50 miles. It was the same thing when I got home; water in the front recesses and the carpet damp about half way back on the floor. I put RTV sealant around the bolts in the front that connect the box to the frame. Anyone else have a similar problem and how did you solve it. I prolly won't use the trailer again until next year but would like to be proactive and get it fixed over the winter. TIA
Spyder Phyl
2014 RT-Ltd, Cognac and Timeless Black 2010 RT-622 trailer.
Do you have the water drain system in the front of the trailer?? (between the front and rear openings) ( a long plastic tray with drains that drains water)
Cruzr Joe
Yes. Installed by dealer soon after I got the trailer. Just had the water problems recently.
check your drains??
Cruzr Joe
That was one thought I had checking those. If they are leaking it must be where they exit through the wheel well since nothing in there is getting wet other the soaking up from the damp carpet.
Spyder Phyl
I've got the same thing going on with my 2010 RT-622. When we left Las Vegas for Alaska everything was dry but then I started noticing that a microfiber I had up in the front stayed nice and wet, even though I hadn't run it under any water. Both wells in the front were full of water and I still haven't figured out where it came from. My seals are pretty much shot but there wasn't any indication that the water came from the top. If you figure it out let me know.
Okay
Spyder Phyl
I have a 13 model & noticed the clear plastic drain piecewas leaking from the plastic pan rubber seal going down. Also had to adjust the front door latch. Looking in could see light in certain places
I'll be sure to check both of those.
Spyder Phyl
I know not all 622 hatches are true. Try a piece of paper between the seal and the lid. If you can identify the bad spot pull the seal up a bit in that area.
JT
I just checked the drain hose and it didn't seem to be leaking. I did see some light coming in around the seal in one section in front and did the paper test in a few places and it seemed a bit loose. I decided to just pull the seal up all the way around. After that I saw no light and the paper was much tighter. I'll leave the carpet out until the next wash job and check it with a little hose pressure.
Spyder Phyl
Washed the trailer this week and it was still having the leak problem. It was coming in around the seals in large rear hatch in the front. I checked the seals again and could see some light showing so pulled the seals up to the point of almost coming off and used some Gorilla tape to keep in place ( sort of). I didn't water test it again. Maybe next spring when I get it out again.
A few years ago when I had my Gold Wing there was a problem with the seals on the top trunk and the solution was to push a small piece of clear tubing through the seal so it would be harder to compress and seal better. I never did this but some people said it worked. I'm not sure I could do this on the 622's rear hatch seal since it's very long.
Spyder Phyl
Spyder Phyl
I had the same problem. Dealer thighten lightly the screw at the bottom of the front latch. Problem resolve...
Spyder Phyl
Is it leaking near the latch end? You might try adjusting the latch down if possible.
JT
JT
No, it's along the front edge. The fiberglass lip is not very high in this area and angled towards the back to make the seal properly.
Spyder Phyl
Spyder Phyl
Mine is the same. In fact I never noticed anything wet in my trailer except for the very front in the two wells.
Spyder Phyl
In that case check your hinge adjustment. On my RT622 they are adjusted all the way down and all the way forward. The seal when pushed all the way down is compressed about 1/2 way by the lid.
JT
JT
I'll have to look at those.
Spyder Phyl
