RT- 622 trailer key barrel removal and replacement.
vtrider
Since I've owned the F3T, I've been wanting to be able to haul my RT-622 trailer. I already posted my install of the wire harness and tail light converter that I needed for the lights to work. My other project took place today in my garage. I needed to remove the key barrel lock from the trailer that I had for the RT and replace it with the new key barrel lock that I had with the F3 so that I could lock the trailer with the F3 ignition key. I wasn't sure how to remove the key barrel. I did some research and found these YouTube videos that really helped me out. I was able to do this installation without to much difficulty after watching the videos. The only thing I did different, was not to remove the whole lock and lever assembly from the trailer. I was able to keep this installed on the trailer and take it apart connected to the trailer.
