RT-622 Marker lights
Uticat
Hi, just noticed one of my red trailer marker lights is burned out (checked with circuit tester). These seem to be sealed LED fixtures (and fun to remove). Anyone have a part# replacement or upgrade suggestion that will fit into the recess of 4 x 1-3/4 x 3/4 with 3-1/4 bolt spacing? They are stamped 12V @ .75W. I would like to find something a bit brighter if possible.
Thanks.
Pm me with addres
Thanks.
The link above in DJ's thread shows my trailer after replacing the factory LED lights with ones from etrailer.com. I still have the original lights and your welcome to them, but honestly I'd replace them with the ones I used, or a similar brighter led. If you'd like the ones I have pm me your address.:thumbup: There yours
Thanks for the offer and the information, I like the look of the etrailer led's better than the factory dim looking one's. I'll be getting all 4 new ones. Do the mounting holes line up ok?
Minimal drilling require
I had to enlarge the center hole slightly and then one of the two mounting hole was moved slightly as well. It was EXTREMELY easy. I bought a sheet of cork gasket material from the auto parts store for $5 and cut out new gaskets, as the etrailer do not come with them and then used all new stainless steel bolts and nuts so that I never needed to worry about them. The most difficult piece was removing the old ones, as you have already found out.
