RT-622 Bearings
revjvegas
Wondering if anyone with the BRP 622 trailer has found an outside source for bearings and seal for the wheel hub.
It just seems so, well ... retarded, to have to replace the entire hub; especially when the only thing really needed is a fresh set of bearings and some fresh grease.
I've repacked mine a couple of times now, but I just know it is inevitable that they will need replacement.
So just wanted to know if anyone else out there had come across some bearings to replace the OEM.
Thanks in advance.
Likely they are regular trailer hub bearings. Have you measured one when you have had it apart to repack?
I bet you will have quite the selection once you get the size...!
Complete new hubs are about $78. Two new bearings are about half that. If you lube them (pack both front and back) they will last a lifetime. Do it each year.
Jack
