RT 2010 Touring Panel lights stay lit - is this a sign of coming trouble?
Was about to drive my Spyder to town and my panel lights all came on -on dash and they never turned off. Just lit up and remained on. Never seen them do that before?
After turning off engine a re-start fixed the issue. Anyone know if it was a signal there's upcoming issues?
You may have a flakey ignition switch or it was not turned all the way to on. Hopefully it does not happen again.
:agree::thumbup: No codes good thing, maybe just double check battery for fun of it:popcorn: play with ignition & multiple keys:dontknow:
check your battery cables to see if they are loose. The early model RT is notorious for having the cables come loose. When you have a chance put star washers under the bolts to keep them tight.
Maybe a relay stayed engerized??? or stuck in the on position...Inpossible to find unless its acting up...HOPEFULL it was just a one time thing??? larryd
