RS HEATED GRIPS
Sempyder
Just wondering what people are using for heated grips on a MY 10 RS. Does anyone know if the BRP 219400613 heated grips will work for the rs, the book says ST. Do they not make any option for the RS? Thanks for any input.
Aftermarket solutions that install cleanly?
Patrick,
Patrick,
yes the aftermarket ones are easy install use the printed circuit looking ones I even was able to reuse the stock grips use a small stiff wire like a 1/8 in welding rod and carefully work under the grip then spray wd40 into the gap and work the rod around the tube ,I was able to mount the switch into the slots beside the gauge cluster $40 and they are great
