JRWW
Went to start my 2010 RTS SE5 and tacho jumped all over the place from 1000- 2500 rpm, twist the throttle and would not rev at all. Dash showed EBD fault. Turned off and removed key, walked away to allow things to shutdown. Went back started normally as if nothing had happened. Next day pulled into gas station shut off refuelled and went to start, same problem. Again walked away and restarted without any problems.
Has anyone got any clues?
