Rough Idle on startup, settles once warm - any ideas?
Patt
My 2019 F3 Ltd is idling rough on startup, settles down once it gets up to running temperature, but rev counter needle still fluctuates between 800 & 900 revs, bike has a stage 2 tune in it, when hooked up to diagnostic tune reader there's no fault codes. Should I be worried? Done 40000 Kays. Thanking you John
Who did your Stage 2 Tune?? I'd give them a call & ask, but I reckon it sounds like it's doing pretty much exactly what you'd expect... rough idle until warm, and the electronic tach needle bounces a bit at idle... :rolleyes:
Ride More, Worry LESS! :ohyea:
Peter it was Jase, done about 15 th kays since installed, will be getting the 45 th kilometers service done shortly, plugs & fuel filter replaced. lnteresting to see if anything changes. Thanks for the reply.
If you're concerned, give Jase a call, I'm pretty sure he'll be happy to talk any concerns you might have thru with you. :thumbup:
