Rotating the Front Tires
jimcrom
I have 8500 miles on the original tires and I am noticing some additional wear on the inside passenger side tire. My thought process was to rotate the front tires. Is that safe or am I asking for trouble.
You can rotate, but you'll also have to remount them as they are designed to rotate in only one direction. -Though I'm not sure how not doing that will affect handling on the :spyder2:.
I had a co-worker who had this type of tire on their car... The garage tech mounted one the wrong way, and it was causing the car to pull and vibrate.
As mentioned the tires are rotational so dont switch them.Sounds like you will need the dealer to check your front end alignment.
