DriftersWay
Directional tires usually do much better in the rain. They typically resist hydroplaning much better than Non-Directional tires. Since the Spyder is susceptible to hydroplaning, and it can be quite hazardous, it isn't a bad idea to stick with this kind of tire. Good traction in the rain is worth much more than being able to swap sides without dismounting the tires.
And, if you have good alignment. Front tire wear is typically pretty even, eliminating the need to rotate.
Absolutely correct.
