Rollo alignment question.
Zummyannie
Had my spyder aligned by inventor Mike Loescher at his home in Florida two years ago. The f3 has been a different machine ever since. Wonderful fix for the factory misalignment. I need a new rear tire. Will this required another Alignment? Thanks
No. If you put it back in the same spot you should be close before you changed the tire.
:agree: …. when you remove your rear wheel … do it so you don't have use the adjusters …. it will then be in the same place...… good luck …. Mike :thumbup:
Go to YouTube and look for Finless's video on how to remove the rear tire without changing the belt alignment and tension. Very good video.
