RoboBracket
I'm normally a "function over form" guy, but my first impression was that it was a bit too much like an Erector Set for me. Probably works great.
I have the GIVI shield which I like quite well, but I've been thinking of adding some half-inch spacers under the shield , with longer screws, to let a bit more air under the shield. Still a bit too much buffeting as is. Maybe that will solve it.
After owning a V-strom and adding a Madstat bracket here my take:Will order the Madstat before I take delivery of the Spydee.It's that good.
The reason:It adjusts in all angles.
For those who don't make it to the mod threads very often, I'm providing a link to my post for the Madstad RoboBrackets. It's a windshield system similar in concept to the CHAD windshield. Debbie and I were looking at them as an option to get adjustability out of nearly any aftermarket or even the stock Spyder windshields.
http://www.spyderlovers.com/forums/showpost.php?p=136644&postcount=16
Having had Mark at Madstad install my Buell windshield and adjustable brackets personally in his shop in Florida before my ride to New York , I can attest to the engineering and workmanship he puts into his products. The end result in my ability to control airflow was incredible. I ordered mine today for the Spyder. :2thumbs:
John , The silver color against the black console is the main culprit there... Maybe Mark will start powdercoating them , in the meantime , a nice coat of flat black paint would eliminate that concern.
mm, I like the spacer idea. I'm still getting some buffeting with my Ultra Touring windshield at freeway speeds. I wonder if it would weaken the windshield or fairing at the mount points too much with just spacers under it (less surface to surface area)?
The RoboBracket does look like a cool concept too.
I gotta visit the Mod Forum more often . . . .
. . . . I have been waiting for these! :clap:
I just ordered mine. It is seldom that I get excited about a new product or ordering a new mod - this is the exception. (well, maybe the 2nd - I was real excited when I ordered my Spyder)
I need an adjustable flexible windshield system.
My eyes seem to be particularly sensitive to wind.
I wear glasses, bifocals.
My helmet is an auditory nightmare in wind, but nice otherwise.
I ride year around, temps ranging from 40 to 110.
The miles I ride are 80% highway and 20% city.​
The CHAD and F1 get great customer satisfaction marks, but the size and style just don't do it for me. While the common appearance complaint is they look like a giant toenail, to me, they make the Spyder look like the Hive Queen in Aliens. Probably attractive to some, not me. I am also not into paying $300+ and then having to re-mod (cut and shape) my mods. That is just me.
I expect the RoboBrackets/Windshield to meet and exceed my needs. If I want, I can re-use some of the other windshields I have for special situations or purposes. Matt has a fantastic reputation for high quality, functional, and high performance products. The install instructions are well done and look like a snap. Plus he guarantees your satisfaction. Add to all this, Brian & Deb's test results, I don't have any doubt, just anticipation.
I just had to share my excitement on this.
Tom
I think making the brackets black would help the looks-- and maybe going with a 1/2 tint on the bottom of the shield.
It kind of looks like there are knobs that are on the front of the windshield to hold it to the bracket???? :dontknow:
Yes . . . .
. . . . I agree, if they were black, they would almost be invisible. Maybe in the future they will come in black. I have no problem painting them black or some other color - or using a flat black electrical tape on them. I was thinking that I might put reflective tape on the edge against the windshield for added visibility and 'flash'.
I think the tint on the BRP Sport Touring windshield is nice, but I am also expecting it to be a distraction if I put it on the RoboBrackets - having the tint in different locations depending upon the settings may not look so good. Just a matter of my taste or lack of it. I don't see any functional reason for having tint on a windshield that small.
Tom
I have my order going in as well. I am very excited about Mark and the Madstad products. He sent me another email yesterday and I wouldn't be surprised if we didn't have another SpyderLovers sponsor on board soon. He makes a quality product and I do believe he is looking into some additional options. I am sure he will post information or pass it along as it comes in. He has been very busy with this and his other products. Here are the photos and video Brian has of the set up on his spyder.
I also took a few pics of the Madstad windshield fully lowered and fully raised to help give an idea of the limits of it's adjustability.
Fully lowered.
Fully raised.
I also made a little video showing me moving the windshield through a good portion of it's adjustable range so someone could get an idea of how much the brackets allow you to move a windshield. Note that I left my handlebars at full right turn and the windshield clears the clutch lever at all but the most radical angles.
[nomedia="http://www.youtube.com/watch?v=Z9vTzFiOvxo"]YouTube- Broadcast Yourself.[/nomedia]
Mine arrived today (it took only 1 week to Canada) but I can't get to install it before Sunday night. I'll be using my 23" BRP screen, so I'll report back on how it goes.
Rod.
I would be concerned about that too, depending on how big the windshield is and how thick it is. I'm not saying I wouldn't try it but just to be aware that the windshield can break. Also, the cast metal that the windshield mounts to has threaded holes that can be easily damaged. Be sure you get long enough screws so they can get full thread mating when you add your spacer.
Yep, he uses little wing bolts to hold the windshield to the bracket. It makes for easy on, easy off of the windshield. I guess the benefit would be for when you adjust the shield and need to tighten all 8 bolts, it's easier to get at them with the windshield off. :dontknow:
I guess the other benefit of the wing bolts is if you wanted to quickly swap a second windshield depending how/when you're riding. I'd be curious if I could get the RoboBracket to give me decent performance out of the stock shield during short slower speed trips and use my larger shield for longer freeway trips or adverse weather. Of course I'd still have to adjust it I suppose for each shield. This bracket is tempting the tweaker side of me..
I got my RoboBrackets installed tonight with my 23" BRP screen. Everything bolted together very nicely and after a quick blast up the highway for a road test, it seems great. :clap: Mine's black and it looks better than unpainted IMHO. I'll post a photo tomorrow (if I figure out how...).
For the 1st time ryding the Spyder, I heard the motor and the exhaust sound. Can't wait for a longer ryde!
Mark was very good with the questions I had and I highly recommend this product and his service.
NFI,
Rod.
NFI,
Rod.
So you drilled and mounted the BRP 23" onto the Robo?
What did you do with the 'stock' holes down at the bottom of the shield?
Yes, I drilled 4 new holes. I'll just have to find something to plug the old holes.
Rod.
The wind behind your sail
I think that you're on the right track, John. My GTR Kawasaki has a vent below the windshield that directs air up behind the screen, and there is no buffeting. My Chad screen does the same thing by being mounted a few centimetres away from the rest of the fairing., and there is no buffeting behind it either.
My '76 Moto Guzzi Convert has a police style barn door fairing and the buffeting behind it is terrible. As I'm (very slowly) rebuilding it, I'll add some spoilers to direct air up behind it. I expect that the buffeting will disappear.
Cheers;
Pogo.
You promised!!!!!
NFI,
Rod.
Rod, I am still waiting. Please, get off the Spyder and post your pictures.
Maybe this will help on the how-to;
http://www.spyderlovers.com/forums/showpost.php?p=137218&postcount=3
Thanks!
Tom
