spyderbirds
OK, headed out for a full day of over 400 miles touring West Virginia and multiple sites to stop and see as well. About thirty miles into the day as I round a corner and cross a bridge I note that the spyder has not downshifted and I am still in 4th gear. GRRRR wont downshift, was able to chug ahead and get pulled off the road past the bridge.
Now thankfully I had read on this forum about the shifter linkage coming apart and I actually do check this item when doing oil changes.
I took a quick look to see if there was any hope of a fix without undressing the RT. No Chance.
Removed the Tupperware and was able to reconnect the linkage, then after starting the spyder and was able to get it back into neutral.
Wondering if I had it on correctly I went ahead and replaced all the Tupperware and found that indeed I had access to all 5 gears and was on the road again.
Moral: It does pay to do some of your own wrench work and also is valuable to read this forum as well.
