Risers
none for the rt,so most others have had there seats made to sit futher away or closer,which ever you need.:thumbup::chat:
Was looking into making a riser plate for our RT. But the TBW is making the application almost not worth the hassle. TBW...Throttle by Wire. I'm still trying to figure out an easy but cost effevtive way to make it happen.. The seating position is the best and most simple fix.
We have a 2013 on order and I ordered the adjustable handlebars to be dealer installed and BRP has already shipped them and they are at the dealer's. You might want to check with BRP to see if the 2013 bars will fit your machine.
does someone know if the 2013 modells have all the same wholes to fix the handlebars - if so - I hope someone makes an (aftermarket) adapter which could be used also for different applications on all modells ..
